ROBOT New product: New Palletizing Robot M-410/800F-32C
FANUC has newly developed the M-410/800F-32C with a payload of 800kg, as a successor model to the palletizing robot M-410iB/700 with a payload of 700kg.
FANUC's palletizing robot M-410 series has a lineup with payloads ranging from 110kg to 700kg. FANUC has recently launched a new model with a payload of 800kg as a successor to M-410iB/700 with a payload of 700kg, enhancing the maximum payload capacity of the M-410 series.
The features of M-410/800F-32C, a successor model of M-410iB/700, are as follows.
- Increased payload, maximum speed of each axis, and operating range
- Compact J1 base with reduced height, allowing flexibility in installation height adjustments
- Arm integrated cables to reduce interference between cables and peripheral equipment.
- Newly applied sharp design
By taking advantage of these features, the M-410/800F-32C can be used to transport large and heavy objects in a wide range of industrial facilities.
The M-410/800F-32C, powered by the new R-50iA Controller, can utilize the latest features of the R-50iA, and contribute to the automation in the manufacturing industry.
The M-410/800F-32C will be exhibited at FANUC Open House (Japan), which will be held in May. FANUC will demonstrate it in an actual application.
Production of the M-410/800F-32C will start in August 2024.
M-410/800F-32C
(May 2024)
