ROBOMACHINE New product: FANUC ROBOCUT α-C800iC
The ROBOCUT α-CiC series, which is FANUC's latest wire electrical discharge machine, has a new addition:
the large model α-C800iC.
- With an X-axis travel of 800mm and a Y-axis travel of 600mm, the α-C800iC is optimal for machining large molds and parts. Additionally, a Z-axis travel of 500mm is available as an option for machining thick workpieces.
- Similar to the already released α-C400iC and C600iC, the α-C800iC is capable of high-speed and ensures outstanding precision in machining, with its exceedingly rigid body structure, along with the latest discharge unit and discharge control.
- The discharge control, iPulse3, has been elevated to the next level of machining accuracy by optimizing discharge control and EDM technologies, such as uninterrupted machining of small-radius corners and nozzle opening condition.
- The highly reliable automatic wire feeding system, AWF3, allows continuous unmanned operation for a long period of time. In addition, with its simple structure, the automatic wire feeding mechanism has excellent maintainability. The success rate for threading wire is exceptional, and high stability is ensured for a long time.
- With the high-performance display unit, PANEL iH Pro, the drawing time is reduced by 75%. Operations are intuitive to improve ease-of-use. For example, adjustments in machining speed and corner/approach points has become simpler.
The addition of the α-C800iC to the compact α-C400iC and medium-size α-C600iC in the ROBOCUT α-CiC series, completes the lineup.
XY-axis travel | 800 x 600 mm |
UV-axis travel | 200 x 200 mm |
Z-axis travel | Standard : 310 mm Optional : 510 mm |
Wire diameter | Φ 0.1 ~ 0.3 mm |
Maximum workpiece dimensions | 1250 x 975 x 300 mm (X x Y x Z) |
Maximum workpiece weight | 3000 kg |
(June 2024)
