FA New product: FANUC iPC Entry Model
FANUC’s Industrial PCs (iPC) with excellent reliability, maintainability, suppliability and functionality
FANUC iPCs are industrial PCs offered by FANUC which feature reliability, maintainability, suppliability and functionality.
In digitalization of manufacturing, FANUC iPCs can be installed in a wide variety of ways, such as connecting them to a network or combining them with already existing equipment.
High-End / Mid-Range Models
Display Line-up
Along with the high-end and mid-range models, an entry model with an Atom CPU has been added to the line-up.
The control unit of the iPC is 30mm thick, allowing control panels to become slimmer.
The same LCD unit can be selected as the high-end and mid-range models. An 18.5 inch wide LCD model has newly been added to the line-up. Displays of all sizes are fitted with highly reliable touchscreens, significantly reducing the risk of malfunctions resulting from electrical noise interference or cutting fluid/water contamination, which were problematic with conventional capacitive touchscreens. Moreover, FANUC iPC allows operation when wearing gloves.
The operating system is the latest Windows 10 IoT Enterprise LTSC 2021.
Connection is possible not only with FANUC’s latest CNC, FANUC Series 500i-A, but also FANUC Series 30i/31i/32i-MODEL B Plus and FANUC Series 0i-MODEL F Plus.
(December 2024)
